what tyre brands/ model/ rft/ non rft are you running
celica
Post by celica » Fri Sep 19, 2014 3:07 pm
I currently have rft (run flats)
bridgestone dueler hp up front
dunlop maxx at rear
i think i'll be tempted to go non run flats as i did on my e61 5 series and was nicer ride
POC
Re: what tyre brands/ model/ rft/ non rft are you running
Post by POC » Fri Sep 19, 2014 9:18 pm
I just changed to Toyo Proxes T1 Sport all round.  See my thread down there somewhere [emoji106]
Riggie
Post by Riggie » Fri Sep 19, 2014 9:23 pm
Dunlop RFs at the moment, but when they're due for replacement, I'll probably go with non RFs and a spacesaver, the cost of which will be the same as the RFs.
Post by X5Sport » Fri Sep 19, 2014 9:35 pm
20" Dunlop RFT which need replacing soon.  Will buy RFT replacements, probably the same type or newer, but am looking at other makes to see if I can get something that lasts a lot longer.  I've only got just on 16k on the car and the Dunlops have only done around 10-11k of that and have 3-4mm left which is the point I start to get twitchy.  Old habit from working with Police cars which had mandatory changes at 3mm.
Winters are 19" Pirelli Scorpion 'Ice & Snow' RFT.
POC
Post by POC » Sat Sep 20, 2014 3:01 pm
I've just put a full set of Bridgestones in the classifieds section, 7.3mm on the fronts, 5.5mm on the rears [emoji106]
