Page 3 of 3
Re: HELP URGENTLY NEEDED!!!!!!!
Posted: Thu Jun 09, 2016 7:51 pm
by Le Mans
Thanks Mpower I am well chuffed. I've tried the fues for the door lock and checked for any bad connections all good there, I've read that it's a common problem on the x5 models for the doors to sieze up and the mechanisms play up is there any way I can open the rear driver door to get to the mechs? Cheers.
Posted: Thu Jun 09, 2016 7:55 pm
by Mpower
Did you get rid of the error on cluster?
Yes remove door card and the mechanism is inside.
Posted: Thu Jun 09, 2016 9:12 pm
by Le Mans
Ah there is a problem with that! I can't open the door to remove the door card, tried to get the door card off but can't get to the bolts. Any other suggestions? Cheers.
Posted: Thu Jun 09, 2016 9:42 pm
by Mpower
Remove rear seat that will give you more room,give it a try rather than break something,more than likely a actuator failure.
Ignore that method there is a far simpler way around this but not sure is allowed to post here from another forum?
Posted: Thu Jun 09, 2016 9:59 pm
Great news.
Those warning lights are cleared lock-to-lock as above, and are completely normal when the battery is disconnected.
Can't help with the doors though....sorry
Posted: Fri Jun 10, 2016 12:15 am
by Le Mans
Hi didn't get rid of the 4x4 thing on my dash yet will try the lock to lock thing tomorrow will take for a short drive tomorrow and try the lock to lock thing and let you know. Cheers.
Posted: Fri Jun 10, 2016 7:23 am
by Mpower
You have message,you can remove the error on dash by swinging the wheel lock to lock at standstill.
Posted: Fri Jun 10, 2016 3:18 pm
by Le Mans
Hi Mpower thanks for the message. I will try when the rain stops here I've tried the steering left to right but 4x4 thing still there! Cheers.
Posted: Fri Jun 10, 2016 3:50 pm
by Le Mans
Hi Mpower, happy chappy now, just done the steering lock thing on after a little test drive lock to lock and no 4x4 light and if I press the dsc button it comes on and goes off as it should cheers fella.
Posted: Fri Jun 10, 2016 3:56 pm
by Mpower
Good news glad to be of help.
Posted: Fri Jun 10, 2016 8:56 pm
by Le Mans
You have been a big help! Thanks Mpower. Hope I can return the favour someday cheers mate.
Posted: Fri Jun 10, 2016 9:23 pm
by Mpower
You're most welcome glad things have turned out well and no expenditure Incurred.
Posted: Fri Jun 10, 2016 9:49 pm
by Le Mans
Thanks mate your a star.
