Correct Way to Start the Engine
Caesium
Re: Correct Way to Start the Engine
Post by Caesium » Thu Jan 23, 2014 10:37 am
[quote="pvr"]
We don't have a choice with the E70, only a button.
The E70 wakes up when you unlock it with the key, so no "boot up" required as such.
I've seen my glowplug light once in nearly a year of ownership, and that was when it was minus 8.
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
Post by X5Sport » Thu Jan 23, 2014 10:54 am
It may 'wake up' but the systems do not self test until you press the start button without the brake pedal being depressed.  The CIC system also only boots up at that point.  Or maybe the pre-2011 models are different?
Caesium
Post by Caesium » Thu Jan 23, 2014 6:38 pm
The guy that fitted my alarm explained some issues that they had with flashing the indicators in the event of a warn-away, because they woke up the car and caused massive battery drain.
He said some of the systems pre-initialise before the driver opens the door. The glow plugs are almost certainly excluded from this procedure I'd suggest.
Currently :
Previously :
2004 BMW E46 M3
The list goes on...
Post by X5Sport » Thu Jan 23, 2014 10:37 pm
Agreed.  My symbol came on for about a second this evening.  But only when I pressed the start button with the brake on.  2C outside.... :cold:
