Auto fold mirrors.
Re: Auto fold mirrors.
Post by sapphireblack » Fri Jul 05, 2013 5:07 pm
Right now i'm as happy as a dog with two winkles!  After a false start, which then got worse, my stupidity basically, all is good in the folding mirror world again.
I don't really do the oily bits these days, other than the dipstick, but £500 for a carcass assembly Vs £50 for the repair kit is a bit of an incentive to get in and have a go  :)  Curiously the kit contains parts that do not apply, in that they are not present in my mirror but they are perhaps relevant to other BMW's, i don't know.
So the problem was here.
These two gears operate at right angles to each other, one is somewhat worn!
Just these two gears are needed in the repair, the cast casing frankly is poor quality and as the original had no wear and fitted rather better, i elected to re-use it. The one shown is the new one.
These parts have no home in my mirrors,
So i reckon an hour tops for this job as long as you don't do what i did! It's tricky to explain but the 'stub' shown in my early picture once the mirror body is lifted off, has another casing inside released from the underside access panel. This in turn houses a spring loaded sprocket which i dropped, in doing so it separated before i could even get a visual on it let alone index mark it. It reassembles easily enough but in multi positions only one of which is right, but you have to basically fully reassemble before that is discovered  >:(
For anyone accomplished this would be a breeze it's fiddly more than difficult. I am really happy to have two functioning mirrors again and i realise now the failure was waiting to happen as it had become jerky and noisy on the drivers door. For £50 spent and a couple of hours i am chuffed  8)
Oh for Sanj.
No need to strip out the door interior, everything is easily accessed from the outside which i regard as a bonus  ;) four screws are upside down but not hard to reach.
2009 35d, Space Grey with Chateau leather, just crept over 40k miles.
Rusty
Post by Rusty » Sat Jul 06, 2013 12:00 am
Nice one.
I did wonder where all the bits in the kit might go, but after stripping mine I too figured that some might be generic.
I'm glad you have had more success than me!
Sorry no pics as I find it very difficult to grapple with a camera or phone whilst trying to hold together several small and greasy parts without breaking something or everything.
I stripped the whole lot down, and be prepared if doing so to have fun as I did getting the 'circlip' back into the heavily sprung detent clutch outer casing (which needs to be well greased).
After stripping it, re-greasing it and re-assembling it, it is still sluggish so I now need to look at the motor & supply to see if that is the cause of the problem.
The saga continues but good weather has halted play ;)
Runabout - E92 3 Series Coupe
