E53 rear half shaft removal
At least you know where it is now and don’t need to go all ‘Tarzan’ with the half-shafts.
X5-D-Sport
Hi Leslie, Henry & X5Sport chaps,
I have found that the part number for the correct prop as quoted by ebay for my X5 D-Sport 218hp 2005 facelift.
REAR PROPSHAFT 7549298
Whether I believe ebay or not is another issue.
Anyone here have ideas if this is the correct prop or not,
as I’m still recovering from Covid,
& need 30 minutes recovery time from just a few minutes grovelling under the X5,
and cannot be wasting time unfortunately, & making myself more ill than I already am.
Regards
Grant B
Ebay parts that ebay quotes will fit – links
https://www.ebay.co.uk/itm/166943059360
and
https://www.ebay.co.uk/itm/315672771079 ... ondition=4
Regards
Grant B
and
- henrym3
Whilst you were scrabbling around under there did you write down the p/n on your prop. It’ll be on it somewhere and if it matches those for sale I’d be well confident it would fit.
X5-D-Sport
unfortunately, the part number is not visible on the original part
As long as you have a face lifted E53 then yes. Used from 23/12/2004 onwards on the 30d/30i and 4.4 only. It should be 1,347mm long. Full part number has 610 on the front.
Prior version (2003 to 17/1/2005) is: 26107524364. I assume the date overlap is when they ran out in the factory in the US.
Realoem says this:
https://www.realoem.com/bmw/enUS/showpa ... 6107549298
Realoem says this:
X5-D-Sport
I will get my goefer to get under the car mid week with a scrubby pad & see if he can find the number...
