Dismantling Headlamps - to raise High Beam only.
Post by henrym3 » Fri Jul 02, 2021 1:20 pm
Thank you for that Greydog. I’ve taken a screen shot and added to the list of jobs.
Post by Greydog » Sat Jul 03, 2021 7:13 am
Mornin D Sport
While walking the dogs this morning I had a light bulb moment
Did I read in another post some time back that you raised the ride height on your X5?
If you did, did you adjust the headlamp levelling sensors by the same amount ?
X5-D-Sport
Post by X5-D-Sport » Sun Jul 04, 2021 7:37 pm
yes, you remembered well... the ride height is not the issue...
the issue is that the Main AND Dip aim at the same distance, so even with main beam on, the ball of light sits on the road where the dip beam line ends... raising the aim simply dazzles the oncoming traffic with the dip beam & the mains are still not high enough.
Post by X5Sport » Sun Jul 04, 2021 9:05 pm
Just a thought (and I may be way off track!), but have you got aftermarket bulbs installed? If the filament is incorrectly set (or the arc if HID) then it could throw the beam out. If you put a reputable brand of lamp in (such as the OEM originals unless those are the ones you are using in which case ‘cancel my last’) does it change anything?
X5-D-Sport
Post by X5-D-Sport » Sun Jul 04, 2021 9:41 pm
Hi Richard, I think you are onto some thing here..
In theory the main beam should be spread out more & these head-lamps have HID's fitted.
My previous X5 was a year older 2004, & may have had a slightly different reflector, but those lights were spot on with HIDs fitted.
I will have a play in the week.
Post by Greydog » Mon Jul 05, 2021 8:09 am
Sorry D Sport I missed you had Bi Xenon lights fitted my old bus is Xenon Dip Halogen Mains
