Page 2 of 4
Re: Coding help
Posted: Tue Apr 17, 2018 12:55 pm
by Rassi
[quote="britishlion"]
What haven't we changed !!!
Well Anthony seems to have turned his x5 into an M4 !!
you can code the interior sound - so we changed that to an x5m !!! sounds so much better
so far I have done
X5m - interior engine
halo brightness to 40%
M screen on start up
handle lights in reverse
sport on start up
Is this a wind-up? Can the active sound be modified? This is with Bimmercode?
Re: Coding help
Posted: Tue Apr 17, 2018 1:46 pm
by britishlion
It absolutely isnt
AnthB has nailed his codes and should post up a video he has taken so you can hear - his is somehow louder than mine !!
all done with bimmercode in the expert area of ASD
Re: Coding help
Posted: Tue Apr 17, 2018 3:47 pm
by RichM50d
It absolutely isnt
Definitely more info needed please
Re: Coding help
Posted: Tue Apr 17, 2018 8:16 pm
by Dogzyboy
[quote="RichM50d"]
It absolutely isnt
+1
Re: Coding help
Posted: Thu Apr 19, 2018 12:20 pm
by britishlion
OK
Here you go
Buy the bimmercode app - buy the dongle from amazon -- all in about £45
Then go into your VIN / ECU on the app go into the first option ADS then go into expert mode
In the expert mode
make sure on Slow connection
FO85 model
S63B44 engine
Stereo Audio Level
TL 05 Power Class
code it - go for a drive and smile
Re: Coding help
Posted: Thu Apr 19, 2018 6:18 pm
by Rassi
OK
Here you go
In the expert mode
FO85 model
S63B44 engine
Stereo Audio Level
TL 05 Power Class
Very interesting!! Is the ASD on all the time or in Sport only?
Re: Coding help
Posted: Thu Apr 19, 2018 7:42 pm
by poolie
Well I've ordered mine.
Re: Coding help
Posted: Thu Apr 19, 2018 7:48 pm
by poolie
I've also went into play store for bimmercode it's installed on my phone free!? Am I missing a trick here?
Re: Coding help
Posted: Thu Apr 19, 2018 7:53 pm
by Dogzyboy
You have to pay when it comes to wanting to make changes. At least that’s the case with the iPhone version.
Re: Coding help
Posted: Fri Apr 20, 2018 7:02 am
by Rassi
Keen to get the X5 to sound like a V8 Beast :-[ I unfortunately didn’t manage to get the vgate Icar Pro WiFi to avoid timing out, while reading the ECUs. Was in contact with BimmerCode support and will have another go this afternoon. This timing out business, anyone experienced that?
Re: Coding help
Posted: Fri Apr 20, 2018 7:38 am
by mogsyman
[quote="Rassi"]
OK
Here you go
In the expert mode
FO85 model
S63B44 engine
Stereo Audio Level
TL 05 Power Class
Thanks and very interesting.
I've done that however leaving the audio as TopHifi/Branded TopHifi (0x03), does that make any difference because to be honest my car sounds the same!
I'd also like to know is there any way to get either the gears or rev counter shown in HUD when in sport much like my old F10 M5?
Re: Coding help
Posted: Fri Apr 20, 2018 3:35 pm
by Rassi
Have concluded that the vgate icar pro WiFi adapter is not working, as it times out every time while reading the ECU. Ordered the vgate icar 2 instead, after advice from BimmerCode that are seeing quite a few requests with faulty Pro adapters. Just a heads up.
Re: Coding help
Posted: Fri Apr 20, 2018 9:26 pm
by poolie
Anyone else had this problem what rassi is having as I've just ordered what was recommended via the link..
Re: Coding help
Posted: Wed Apr 25, 2018 7:16 pm
by poolie
Well I got my coder today..... Well what can I say, the acoustic upgrade is mint.. loud as f--k
Re: Coding help
Posted: Wed Apr 25, 2018 9:26 pm
by Rassi
[quote="poolie"]
