Resetting the gearbox
jdwright590
Post by jdwright590 » Fri May 23, 2014 6:20 pm
Not long ago became an owner of a 2005 3.0d Sport, loving the car so far and actually am not as disappointed in the mpg as I'd feared...see 26mpg around and about, and today saw over 39mpg on a 25 mile motorway jaunt :)
Anyway when I got the car I didn't bother to reset the gearbox memory, and although I am pretty fine with the way it drives I do sometimes wish it was a little more anxious to change up (know I can use manual mode but am a little lazy!). This is my first diesel, first automatic and first 4x4 so maybe it's just me not being used to the engine getting this big beast up to speed, BUT do you think it's worth me resetting the gearbox now (after 3 weeks of ownership) or will it just not make much difference/settle itself eventually.
Hope that question makes sense! Here are a few pics of my car if anyone's interested :)
fenj66
Re: Resetting the gearbox
Post by fenj66 » Fri May 23, 2014 6:31 pm
hi there, nice looking car!
mine is of similar age, i occaisionally do the soft gearbox reset, it does make the car feel more zingy! and less sluggish, but it seems to go back to normal after a few days  :(
Lol. Maybe the gearbox knows me better than I think. , and I just drive like a slug!!    :))
Lemans x5
Post by Lemans x5 » Sat May 24, 2014 8:30 am
Hi,
How do you do the gearbox reset?
Would be interested as mine feels abit sluggish when changing gears.
Doug
Post by X5Sport » Sat May 24, 2014 9:23 am
It should be no more than turn the key to Pos2 (don't start it), floor the accelerator pedal for 30 secs and switch off.
Start the car and drive away.  The 'adaption' procedure will then relearn 'you' as a driver over the next few days.
Lemans x5
Post by Lemans x5 » Sat May 24, 2014 10:26 am
Thanks for the info.
Doug
jdwright590
Post by jdwright590 » Sun May 25, 2014 7:14 pm
Thanks guys, I'll give it a try and see how it goes :)
AVI-8
Post by AVI-8 » Wed May 28, 2014 1:26 am
I'm presuming you're used to a manual, I've just recently bought my X5, love the car, it's my first auto after 26 years of driving a manual, my last car was a 5 series with the same 3.0D engine which has bags of torque, in normal driving situations ie, just taking your time, changing gear at 1500 rpm would be more than sufficient due to the torque, unfortunately autos work differently and change gear at a higher rpm which not only takes a bit of getting used to but also seems to be not very efficient ... You'll get used to it, it's just the way autos are, I have the sport model and it seems to think I always am always about to want loads of power available and hangs onto the rpm even under light loads rarely changes up below 2000 rpm ... And the ridiculous down shifts on a steep downhill slope if you brake is quite something, I saw 3000 rpm the other day with a cold engine which  I would never do, to the point that when driving on steep hilly roads I always select manual mode now, though I've read that switching stability control off prevents this ... Haven't tried that yet
Current
2006 X5 Le Mans Blue Sport Edition 3.0D
1991 Porsche 911 Carrera 2
Steamyrotter
Post by Steamyrotter » Wed May 28, 2014 1:13 pm
Just to clarify Richards point......
The 'adaption' procedure will then greatly annoy 'you' as a driver over the next few days.
Please note...
