EGR blanking
kamb
EGR blanking
Post by kamb » Fri Feb 21, 2014 8:20 am
Guys got error codes
4262 glow plug 6 out
4501 exhaust had recirculation control deactivation
On start up getting small cloud of white smoke smells like diesel
We have changed glow plug deleted codes and taken for drive
Code 4501 still comes up
Question is would blocking the thin vacuum pipe blank out the egr valve and possibly stop the white smoke on start up?
Or do I need to buy a blanking kit
Re: EGR blanking
Post by X5Sport » Fri Feb 21, 2014 11:31 am
The small puff of smoke is completely normal, more so on cold mornings.  Diesel engines take a few turns to fire, hence the smoke.
kamb
Re: EGR blanking
Post by kamb » Fri Feb 21, 2014 2:24 pm
Any ideas about the blanking?
jason@bwchiptune
Contact:
Re: EGR blanking
Post by jason@bwchiptune » Mon Feb 24, 2014 9:25 pm
If your car I'd 2003 upwards the egr can be set to permanently closed through software
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
kamb
Re: EGR blanking
Post by kamb » Tue Feb 25, 2014 12:24 am
Cheers Jason
do you think it may be already closed as per error message?
its a 2004
jason@bwchiptune
Contact:
Re: EGR blanking
Post by jason@bwchiptune » Tue Feb 25, 2014 12:42 am
When I close the egr by software there are no error messages
You will need to look at the egr actuator valve or diagram in the egr
02085611818
kamb
Re: EGR blanking
Post by kamb » Fri Mar 07, 2014 7:10 pm
blanked the Vacuum hose from the EGR today with a m4 bolt
since I have noticed the smoking on start up has gone and also car runs ALOT better
one question though is when on high revs the car now hisses a bit like a dump valve
could this just be a bit of air leaking out from Vacum hose>?
TBH it sounds very beastly
kamb
Re: EGR blanking
Post by kamb » Sat Mar 08, 2014 4:47 pm
**BUMP**
jason@bwchiptune
Contact:
Re: EGR blanking
Post by jason@bwchiptune » Tue Mar 11, 2014 2:36 pm
I would advise you to get someone to have a look at it
02085611818
kamb
Re: EGR blanking
Post by kamb » Tue Mar 11, 2014 6:25 pm
Spoke to local garage he reckons egr is stuck open.
He said blocking the vacuum hose is ok but will damage swirl flaps maybe in future
Told him that X5 doesn't have them but he adamant car does anyone got any ideas?
Re: EGR blanking
Post by X5Sport » Tue Mar 11, 2014 8:54 pm
No swirl flaps on that engine when fitted to the E53.  It's a recurring myth that just because other cars with that engine have swirl flaps (like our E46) they all have them.
The X5 was only approved to Euro 3 and didn't need them.  It's also why the exhausts point downwards as there is no DPF either - which it would have needed to get Euro 4.
kamb
Re: EGR blanking
Post by kamb » Tue Mar 11, 2014 9:22 pm
Cheers guys ill prob leave vac hose plugged then as new egr is £150
storminmike
Re: EGR blanking
Post by storminmike » Tue Mar 11, 2014 9:26 pm
[quote="kamb"]
Where did you block it?
Also, if you dont block it properly will this affect the turbo and/or brake servo vacuums?
kamb
Re: EGR blanking
Post by kamb » Tue Mar 11, 2014 9:27 pm
Blocked it from the vacuum hose only
storminmike
Re: EGR blanking
Post by storminmike » Tue Mar 11, 2014 10:01 pm
[quote="kamb"]
....as in pulled it off the egr and blanked it....the hose that is?
Pipe 4 here?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=45
