ps2 install
DSowerby
ps2 install
Hi chaps
Looking at putting ps2 slim in x5 Found an rca lead on the bay to get picture on screen but not sure how to hard wire inverter. Most come with a cigarette socket on end. Could I just simply cut of end and wire to back of cigarette socket? Or should I wire straight to batt with a relay t which activates when ignition is on.
james8whippy
Re: ps2 install
Hi Mate,
I fitted a slim line PS2 to mine and used a cable similar to this
http://www.ebay.co.uk/itm/NEW-Sony-PS2-Slimline-70XXX-In-Car-Charger-Power-Supply-12V-Adaptor-in-UK-/290621393620?pt=UK_Video_Games_Cables_and_Adaptors&hash=item43aa628ad4
I just chopped the cigarette end off and joined it the cables to a relay which took power from the battery and then remote turn on from the main audio relay in the right hand cupboard.
Hope this helps
James
Hope this helps
James
DSowerby
Re: ps2 install
Thanks for the reply pal, the lead is what I got saved on the bay. Don't suppose you have a drawing of the main audio relay
Cherrs
Cherrs
james8whippy
Re: ps2 install
I don't unfortunately mate I think it was the left hand blue relay on the left off the top of my head.
I think Sanj told me which one it was. Sanj can you help?
If not if you have a multi-meter you can test each relay until you find one which is ignition switched.
Sorry I couldn't be more helpful!
James
James
- Sanj
Re: ps2 install
I wired up to ignition positive so the PS2 shuts down when the car is switched off.
Is this what you mean?
james8whippy
Re: ps2 install
Thats the one! Cheers Sanj.
DSowerby
Re: ps2 install
Thanks guys
Just awaiting my ps2 from the bay.
snipez999
Re: ps2 install
I recommend a wireless joystick it's easier to handle when you're driving
Re: ps2 install
[quote="snipez999"]
Not literally one trusts though...... :drive:
