Possible group buy - DI Vessel
Re: Possible group buy - DI Vessel
Post by X5Sport » Mon Jul 16, 2012 3:04 pm
Definitely worth the investment.  Anyone else finding the water feels almost 'soapy'?  Definitely an excellent 'Group Buy'.. :ok: :bigthanx:
I know my resin won't last as long up here, but just not having to chase off the water spots even in strong sunlight makes such a difference..... :D
mogsyman
Post by mogsyman » Mon Jul 16, 2012 9:44 pm
At 550ppm from the tap your water is almost nuclear and you'll go through resin quicker than you can say 'water stain' ;)
Sent from my iPad using Tapatalk HD
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Rusty
Post by Rusty » Mon Jul 16, 2012 10:43 pm
Raj had better sort the resin group buy then, even if it just for X5sport  :)):P:))
Sent from my GT-I9000 using Tapatalk 2
Runabout - E92 3 Series Coupe
Raj
Post by Raj » Tue Jul 17, 2012 7:23 am
[quote="Rusty Nail"]
Don't worry, I'll see what we can sort out.
Anyone know what the TDS reading is that waterspots will start to appear again?
Post by X5Sport » Tue Jul 17, 2012 9:22 am
In my case - 10 mins after it's first used.... :P :P
My rain water supply is about 40ppm and that doesn't 'spot' but then I'm not going to hazard a guess as to what the TDS is reading..... :blink: :'(
pvr
Post by pvr » Fri Aug 31, 2012 11:49 am
Still working Richard?
911 50th anniversary -
Raj
Post by Raj » Fri Aug 31, 2012 12:01 pm
[quote="pvr"]
Mines now showing 20ppm and there were a couple of spots appearing on the bonnet.....hmmmm
Can't be starting to run out already.
Group buy for resin anyone...lol
pvr
Post by pvr » Fri Aug 31, 2012 12:04 pm
I can see it at the meet ... backs of substance being exchanged in some industrial estate between blacked out X5s  :))
Raj
Post by Raj » Fri Aug 31, 2012 12:10 pm
[quote="pvr"]
LOL.
Out of interest, what sort of ppm reading does yours tend to be when you have to replace the resin?
pvr
Post by pvr » Fri Aug 31, 2012 12:11 pm
Not replaced it yet !!! It is supposed to last at least 12 months, what is your water reading from the tap again?
Raj
Post by Raj » Fri Aug 31, 2012 12:16 pm
[quote="pvr"]
Need to check again. Think it was something like 300ppm.
It could well have been water from the jetwash drying unusually quickly but me thinks not.
Am just waiting on a call back from Doug to hopefully shed some light.
pvr
Post by pvr » Fri Aug 31, 2012 12:49 pm
Yours is twice as much as mine though, so pretty hard.
I have been washing so many cars a week every week and still is all ok on my side though.
weirdfish
Post by weirdfish » Fri Sep 07, 2012 10:50 am
A bit concerned regarding the reading I'm getting from the vessel already, water going in is 260ppm water out is 93ppm, and I've only done about 6 washes, can this be right.
The water butt is reading about 15ppm, but don't want to use that yet as I haven't sorted a filter system for it.
Post by X5Sport » Fri Sep 07, 2012 11:22 am
I made my water butt filter like so.....
One of these Karcher in-line filter units (fits all newer machines) and I adapted it by adding a Hozelock 2289 Adapter on the other end.
and voila.....Image
Provides a super fine mesh filter that goes in line between the water butt pump and DI Vessel.  I also use this stuff to keep the water cleaner.
Had a tap start leaking on the water butt a couple of weeks back and used the pump to empty it into a kiddies sandpit/paddling pool toy, washed the butt out, changed the tap and pumped the clean water back in again.  Well happy with the whole system.... :ok:
With our mains water being at a TDS of 500+ I don't have an option, or I'll be changing the resin every month or so.  I also drain the DIV after every use.....no idea if that makes a difference to the resin's longevity or not?
weirdfish
Post by weirdfish » Fri Sep 07, 2012 1:55 pm
Brilliant, will order today, Thanx.
Still a bit concerned about the length of time the resin has taken to become partially innactive.
