Hi guys
Anybody had any issues with the washer fluid tank leaking?
Mine must have some sort of leak from behind the tank and it keeps emptying the fluid!
I the impression it's only 2 bolts holding the tank in place and a quick removal should see if any pipes have come off?
Just thought I'd ask if anybody else has had the same?
Max
Washer Fluid Tank leaking?
max
- Rusty
Not had the same but yes, two bolts (10mm heads) and the tank is free.
Hope it is only a pipe or something simple. While the tank is out, it could be worth cleaning out the filters etc.
Hope that helps
Hope that helps
Runabout - E92 3 Series Coupe
Re: Washer Fluid Tank leaking?
This is the TIS for getting the washer tank out....
phill
it could be coming out of the pumps themselves, I had this problem earlier this year. first on the front screen pump and then about 2 weeks later on the rear screen pump.
Phill
Phill
2003 X5 4.6is - Now dead
max
Thanks guys
I'll try and have a look tomorrow
X5 D Sport
some of my old toys gallery
splang
hi - an old topic but I have this problem too in my e70 X5 - how easy is it to remove as the TIS link Is dead?
Thank you
S
Thank you
S
splang
answered my own question but others might need in the future so:
http://workshop-manuals.com/bmw/x_serie ... sher_unit/
