Have this message displayed on dash of my 55 plate 3.0D . When I lock the car with lights on the drivers side front indicator stays on!!!!! Strange!
Any ideas??
Check park lights
petert
Re: Check park lights
Check you've not got the indicator stalk in the 'off-centre' position. Might be the parking light. (not 'side-lights' via the main light switch)
Peter T
Peter T
Smeeagain
As the message says "check park lights" have you tired checking the parking lights? I had the same message, with the same indicator symptom - it was the offside parking light bulb that needed changing (hence the message) - its something to do with the bulb tripping out that activates the indicator (I think to show you externally that there is an issue - or perhaps comes on to provide a parking light in the absence of the faulty one?
Smee
Smee
- pvr
Correct, when sidelight is out the indicator stays on.
911 50th anniversary -
gobiman
Had this problem with new Angel eyes. Loose connection and needed pushed in a bit harder.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Z1 1989 Top Red
Pradaman
It is a sidelight bulb out cheers for the replies. It has angel eyes does the headlight have to come out to change bulb?
No. Bulb access is on back of the lamp unit. It's under the sloped rear port cover if I remember correctly.
