Self levelling Xenons too low ? Check this.
Nige
Post by Nige » Fri Jan 06, 2012 2:02 pm
I had an issue last week where the self levelling Xenons were pointing too low. There is no adjustment inside the car.
Whilst changing the pads today, I found the culprit. There is an automatic `adjuster` on the driver side front suspension, this must take the ride height into account and set the Xenon`s accordingly. This had become detached from the suspension and was in the lowest position.
Drivers side wheel removed, this sensor should have the arm secured to the arm
Seen from the back
The `sprung clip` had lost its spring. 2 Cable ties did the job. Its under no load, so this isn`t a problem. obviously, you could try and bend the clip or buy a new one, but this worked for me.
Worth a quick look if you are having issues with the Xenon beam height :thumbsup:
Re: Self levelling Xenons too low ? Check this.
Post by X5Sport » Fri Jan 06, 2012 2:28 pm
Very useful tip....and a neat fix too :thumbsup:
For those looking for the OEM part, it could be item 3 here......
http://www.realoem.com/bmw/showparts.do ... g=31&fg=05
Nige
Post by Nige » Fri Jan 06, 2012 2:31 pm
[quote=""X5Sport""]For those looking for the OEM part, it could be item 3 here......
http://www.realoem.com/bmw/showparts.do ... g=31&fg=05[/quote]
For those not wanting to bodge you mean...:lol:
Post by X5Sport » Fri Jan 06, 2012 2:35 pm
That's not a bodge job, it looks very good to me :D :thumbsup: At least they won't rust....... :(
If you had used Gaffer Tape, then that might be a bodge job... :oops:
pvw10
Post by pvw10 » Fri Jan 06, 2012 4:38 pm
Mine was found also broken between mot's, bought a new one at about £55.00 from memory ( i now blast wd40 on the moving parts every so often).
One at the front and one at the back as you say for headlight stable position, with the front one gone the lights wont move so much under heavy load like fat people in the back, hard braking etc.
Thats its only purpose to move the lights under load in relation to where there set, get set correctly and the two sensors will maintain same thats all.
Post by X5Sport » Fri Jan 06, 2012 4:43 pm
Was that for the complete sensor, or just the bottom bit?
pvw10
Post by pvw10 » Fri Jan 06, 2012 4:48 pm
Just for the sensor complete with the pivot arm plus the cable, i think its just a potentiometer.
Seemed good value to me.
I have the invoice near if needed part number etc.
Post by X5Sport » Fri Jan 06, 2012 4:53 pm
No, just seemed expensive for the bottom arm bit as in this case is all that should be needed. For the whole assembly I guess it's reasonable in this day and age.. :(
pvw10
Post by pvw10 » Fri Jan 06, 2012 4:57 pm
Yes thats true, you get the sensor and the plastic arm and thats it, the parts after that which this chap needed are another piece to buy.
What made me cringe was it was the plastic arm that had broken on mine, with a piece lost and i had to buy the complete sensor :headbang:
PhilT
Post by PhilT » Fri Jan 06, 2012 8:30 pm
Just checked mine and the plastic arm has snapped! If its not under any load do you think it will be fixable with epoxy or something, or does it need replacing?
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
pvw10
Post by pvw10 » Fri Jan 06, 2012 8:43 pm
Its under hardly any load, glue it or add a plate to one side and screw it.
Mine had a part lost otherwise i would have done so. Best you try or buy the whole thing like i had to !
