Steering Wheel Judder under braking
Smeeagain
Re: Steering Wheel Judder under braking
Post by Smeeagain » Mon Dec 19, 2011 3:43 pm
no, no balancing at kwik fit ..... although they have vulcanised the odd tyre for me. And yes I don't think it is balancing either else the wobble would show up at other points other than just braking
scooby1doo1
Post by scooby1doo1 » Mon Dec 19, 2011 3:45 pm
Balance would be at say 60mph to say 65mph, not usually under braking.
Sent from the phone via talktapa
dirtymonkey29
Post by dirtymonkey29 » Mon Dec 19, 2011 5:05 pm
It's a classic lower suspension arm bush tell tale... I'd get a second opinion from another Indy. Not using BMW Care in Leeds are you?
Giblets
Post by Giblets » Tue Dec 20, 2011 2:00 pm
It only judders under braking and drives fine all other times. I will find out the diagnosis soon enough as it's in there today!
53 plate Facelift X5 3.0d Sport Auto - Black - Comms Pack/ Heated Black Leather/ 20" DeCorsas/ Bi Xenons/ Poplar Wood Trim/ Sunroof/ DSP + 6CD/ Alum Run Boards/ F+R Tints
ChewingBacca
Post by ChewingBacca » Tue Dec 20, 2011 3:44 pm
I get the judder the first time I brake. After that everything is fine. May be a warming up thing in my case?
Giblets
Post by Giblets » Tue Dec 20, 2011 5:37 pm
Well she passed the MOT first time which must be a first for any car of mine!
They didn't have time to thoroughly investigate the wobble today but I am going to get the wheel balancing checked again anyway as I am sure things got worse since the 'clunk'
jaynana
Post by jaynana » Wed Jan 04, 2012 7:34 pm
Giblets, i've just discovered i have the same issue (did a 750+mile round trip after xmas through new year, from london to wales, cornwall and back)
when i apply brakes whilst traveling at speeds around 70mph to slow down to around 40mph, the steering vibrates.
this does not happen when applying brakes at slow speeds.
can you pls let me know if balancing the wheels fixes the problem.
thx
j
storminmike
Post by storminmike » Wed Jan 04, 2012 7:52 pm
I had this sort of thing. Vibration under braking from speed tha went away when it slowed down
Servicng the brakes sorted it. I did change both discs and brakes......BUT I noticed one pad was wearing uneven. A good clean of the guides polished smooth and the removal of any notches from wear on the carriers too. The pads ears had made marks on the carriers (not serious) but you could feel them with your fingernail.I dremelled the faces on the carriers where the ears touched
No more wobbles
Disc/Pads/Carrier/Jamming....who knows....problem gone
jaynana
Post by jaynana » Wed Jan 04, 2012 11:46 pm
thanks mate, replacing the whole lot should obviously fix the problem :)
more specifically - i wonder whether its the disks that have gone bad..
dirtymonkey29
Post by dirtymonkey29 » Thu Jan 05, 2012 12:49 pm
[quote=""jaynana""]thanks mate, replacing the whole lot should obviously fix the problem :)
more specifically - i wonder whether its the disks that have gone bad..[/quote]
not necessarily. Could also be caused by worn bushes, typically lower suspension arms.
storminmike
Post by storminmike » Thu Jan 05, 2012 7:46 pm
[quote=""dirtymonkey29""][quote=""jaynana""]thanks mate, replacing the whole lot should obviously fix the problem :)
not necessarily. Could also be caused by worn bushes, typically lower suspension arms.[/quote]
Tis true an all
I posted up my experience mainly because the disk and pads looked a little odd, ECP were doing 30% off and changing brakes seemed easier (to me) than the arms, the wobble seemed to go away again If I stamped a lot lot harder on the brakes. The problem (for me) went away after the disc and pad swap
just sayin
dirtymonkey29
Post by dirtymonkey29 » Fri Jan 06, 2012 12:10 am
If there is pad residue on the discs bad enough for it to cause judder under braking at speed you should be able to feel the pedal pulse if you ride the brakes at really slow speed if the soles of your shoes are thin and your feet are sensitive, alternatively if you have a dti clock dial or can borrow one you can check for run out on the discs
jaynana
Post by jaynana » Fri Jan 06, 2012 4:52 pm
cheers mate, i've noticed from many threads that you actually know these things well :thumbsup: , anyways, i'll leave this problem for the moment untill i have to change the front brakes (i was told its only got a few more thousands left at the last check), ok i'm lying its actually cos my attention has diverted to 2 much more important or interesting matters, on 2 diff threads:
1. my diesel tank filler problem (this is a real prob)
2. scanner 1.4.0 (fun stuff here)
any help on those also appreciated. out of curiosity - where do yo u live btw, dirtymonkey? i'n in north-west london.
j
dirtymonkey29
Post by dirtymonkey29 » Fri Jan 06, 2012 7:09 pm
West Yorkshire (from Kent originally)
dirtymonkey29
Post by dirtymonkey29 » Fri Jan 06, 2012 7:12 pm
If you think it's discs have a look at www.skimmydiscs.co.uk
