Oil change after 2000m
acideraser
Post by acideraser » Mon May 16, 2011 10:10 pm
Hi, I've got just over 2000miles on the clock, just after break-in period. Is it necessary to change engine oil now or should I do it at 10000mies/1 year?
2011 X5 xDrive30d SE Platinum Grey 20" 336 alloys
Re: Oil change after 2000m
Post by X5Sport » Wed May 25, 2011 10:29 am
I had mine done (Oil & Filter) at 1,000 miles as I'm still an 'Old School' engineer, but it doesn't actually 'need' doing. Cost me about £130. Have done with every car I've owned. It's defo good engineering practice.
lezmtaylor
Post by lezmtaylor » Wed May 25, 2011 11:07 am
I would change the oil and oil filter, there is bound to some metal dust and other bits floating around a new engine.
The 'running in' process also can create bits and also cause the engine to run a bit hot and degrade the oil.
So , yes it is good engineering practice to do it and will hopefully give a longer lasting engine.
pvr
Post by pvr » Wed May 25, 2011 4:28 pm
With my M, I did not even have the choice as it was a manufacturer requirement. Therefore I can not see a reason not to do it for other engines though.
911 50th anniversary -
acideraser
Post by acideraser » Wed May 25, 2011 5:11 pm
Thanks guys, I'd prefer to have it done than be sorry later, because I plan to keep this car for some time. I am not sure thsi car has a dip stick as oil level is shown on iDrive . Can this be done at BMW only or any other garage, say KwickFit, would do?
Post by X5Sport » Wed May 25, 2011 5:26 pm
You can probably get it done anywhere as long as you're not breaching any warranty conditions. There might be a dip stick at the back of the engine bay, RHS of the engine. It's not in the manual. On mine it's here:
acideraser
Post by acideraser » Thu May 26, 2011 9:24 am
Thanks a lot!
NewX5
Post by NewX5 » Thu May 26, 2011 11:15 am
Had mine done on 1st service I think about 10500 miles.
X5 Xdrive 30d MSport
Carbon Black
Oyster Interior
Media Package
Third Row Seating
stevee
Post by stevee » Thu May 26, 2011 2:06 pm
[quote=""pvr""]With my M, I did not even have the choice as it was a manufacturer requirement. Therefore I can not see a reason not to do it for other engines though.[/quote]
On the M3, a special , almost abrasive lubricant was used .. which is why it must be changed around 1k miles.
S
X5 E70 (2011)
pvr
Post by pvr » Thu May 26, 2011 7:05 pm
The only service ever to be free from BMW :)
Rusty
Post by Rusty » Thu May 26, 2011 7:36 pm
[quote=""stevee""][quote=""pvr""]With my M, I did not even have the choice as it was a manufacturer requirement. Therefore I can not see a reason not to do it for other engines though.[/quote]
S[/quote]
I can remember that on every engine I rebuilt I would use a special 'running in oil' which had to be changed between 500 and 1000 miles as it had certain additives for cleaning and to help with the bedding in of bearings etc.
I would change the oil without question if I were you, better to be safe than uncertain. Also does anyone know if the sump plug on the X is magnetic? Always good for holding any stray bits.
Runabout - E92 3 Series Coupe
