Electric mirrors, seem temperamental, as does tyre monitor
4.8isFred
Post by 4.8isFred » Tue Apr 05, 2011 5:39 pm
Hi all, having taken ownership of 4.8 model i noticed the electric mirrors very wierd. Pressing the auto fold button the mirrors folded than open again, then the N/S mirror opened and closed then the drivers mirror did the same, both mirrors stationed in the open position? is this the norm? do i need the press the button twice to activate a staioned position? or does the button to fold need to be shifted to the drivers side. Would appreciate some advice on this thanks.
I no from e39 M5 ownership the tyre montoring system plays up alot especially on the m5 not sure if this is the case with the E53?
Driving the car home yesturday noticed the tyre warning light came alite on the cluster but after checking all round couldn't find a fault.
Any advice again much appreciated.
Thanks,
fred.
pvr
Re: Electric mirrors, seem temperamental, as does tyre monit
Post by pvr » Tue Apr 05, 2011 5:55 pm
Sanj has created a how-to for the mirror fix, which you can find here:
viewtopic.php?f=22&t=88
911 50th anniversary -
Sanj
Post by Sanj » Tue Apr 05, 2011 5:56 pm
Beat me to it, by seconds!
pvr
Post by pvr » Tue Apr 05, 2011 5:57 pm
Bit like my 0 - 60 times ... :poke:
Sanj
Post by Sanj » Tue Apr 05, 2011 6:31 pm
Fastest you've probably moved all year! How's the back!?! :poke:
philip600
Post by philip600 » Tue Apr 05, 2011 7:43 pm
'' Driving the car home yesturday noticed the tyre warning light came alite on the cluster but after checking all round couldn't find a fault.
Any advice again much appreciated ''
Hi,
Note sure how the e39 system works but on the e53 the system monitors to rolling radius of the tyres rather then the actual pressure & should be reset each time you check / inflate the tyres.
If this was not done l;ast time they were pumped up the light may come on even if the pressures are correct.
Can't remember the exact sequence but from memory you inflate the tyres to the correct cold pressures ( should be on a sticker on the drivers door )
then turn ignition to position1, press & hold the button on the dash until amber light comes on, start the car & drive off. The light should go out within a few hundred yards & system now set.
It now knows how fast each wheel is turning with the correct pressure, a drop in pressure in any tyre will mean the wheel turns faster as it's rolling radius gets smaller &the system light should come on & warn you.
Hope this makes sense ?
Phil.
2005 3.0d Le Mans auto - Now gone :-( but replaced with an Audi A4 Avant Quattro Black Edition 177PS :-)
1988 Porsche 911 Carrera Cabriolet - NOW SOLD.
1996 Lotus Esprit S4s in Mica Yellow.
4.8isFred
Post by 4.8isFred » Tue Apr 05, 2011 7:53 pm
Thanks guys will check the fix for the mirrors out.
Thanks Phil i'll give that method a go.
I havent driven the car at all today so will check things out tommorow.
Thanks,
Fred.
4.8isFred
Post by 4.8isFred » Wed Apr 06, 2011 11:02 pm
Still havent got round to looking into these issues but will do at the week end and will update. Havent driven the car since monday either so have a bit of catching up to do :)
Thanks again for the pointers.
Fred.
gmc15
Post by gmc15 » Thu Apr 07, 2011 7:59 am
Tyre warning could be a sensor on it's way out ( on the inside of the valve on each tyre). The batteries in them only have a limited life and need changing after about 8 years +. May even be the spare causing the problem. I got sick of the fault appearing on my dash so I got the tyre pressure system programmed out so I no longer get the message. I just keep an eye on the tyre pressures my self :)
x6 M50d
bonerp
Post by bonerp » Thu Apr 07, 2011 8:31 am
My sensor has come on twice since having the car for a little over a month for no reason. Strangely on the same road in the same place lol. Just reset it.
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
gobiman
Post by gobiman » Thu Apr 07, 2011 9:50 am
Not an expert on this, but I seem to remember from previous posts that the tyre pressure monitoring is different between 4.6 and 4.8. On my 4.8, there are definitely no valve-based sensors and my understanding is that the system operates via the ABS sensor by detecting differential braking (ie changes when one tyre deflates).
I've found it pretty good in that it has detected a couple of punctures (both nails) which I've been able to get repaired immediately. However I have had a couple of false alarms where a quick stop and visual inspection have confirmed nothing obviously wrong followed by pressure check when able (I keep one of those cigarette socket inflators/gauge in boot). Always best to check all pressures and then reset via the centre console switch as it differential based.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
philip600
Post by philip600 » Thu Apr 07, 2011 4:02 pm
[quote=""gmc15""]Tyre warning could be a sensor on it's way out ( on the inside of the valve on each tyre). The batteries in them only have a limited life and need changing after about 8 years +. May even be the spare causing the problem. I got sick of the fault appearing on my dash so I got the tyre pressure system programmed out so I no longer get the message. I just keep an eye on the tyre pressures my self :)[/quote]
Hi,
Fred's car is a facelift model & I don't think any of them had sensors in the actual wheel.
As Gobiman has said later systems use the ABS sensors to comparethe speed of each wheel, as tyre deflates it gets smaller & will then go faster so abs sensor picks this up & displays a warning.
Phil.
x555
Post by x555 » Thu Apr 07, 2011 7:26 pm
[quote=""philip600""][quote=""gmc15""]Tyre warning could be a sensor on it's way out ( on the inside of the valve on each tyre). The batteries in them only have a limited life and need changing after about 8 years +. May even be the spare causing the problem. I got sick of the fault appearing on my dash so I got the tyre pressure system programmed out so I no longer get the message. I just keep an eye on the tyre pressures my self :)[/quote]
Hi,
Phil.[/quote]
Agreed thay are also known as pulse generators when using real oem for the part number ;)
I actually find mine pretty useless to be honest :roll:
