Hello ,
I was thinking about replacing the vanos solenoids, been looking for the right replacement's but it's real confusing sort of ment to be for e70 on the other hand there are different type of shapes ect. Hopping someone can lead me in right direction.
The x5 i have is e70 40d 2011
Vanos Solenoid
Vanos Solenoid
My understanding is that the N57 diesel engine isn’t fitted with Vanos. There are no parts referring to such in the parts database. I thought Vanos was only used on petrol engines. What are you looking at that is telling you your engine does have Vanos fitted?
isq000
Vanos Solenoid
Aghh ok, thats why am asking.My knowledge is limited and i learn as i go.X5Sport wrote: Sat May 10, 2025 2:41 pm My understanding is that the N57 diesel engine isn’t fitted with Vanos. There are no parts referring to such in the parts database. I thought Vanos was only used on petrol engines. What are you looking at that is telling you your engine does have Vanos fitted?
Came across this on net
Diesel Engines:
While many BMW engines, especially gasoline engines, have VANOS, it's also present in some diesel models like the 40d, according to a BMW website.
Vanos Solenoid
It may depend upon which ‘40d’ equipped car they refer too. No mention on N57 or B57 (the later engine) for the X5 or X6. The M57 engine didn’t have it either. I’m not clear what purpose it would serve on a diesel as it’s compression ignition not spark. BMW use injection pulse control to adapt power levels to throttle demand and engine load. Given there’s naff all clearance between valve and piston crown on a diesel, having one still open at the wrong point would be catastrophic.
