Absolutely! It's just that occasionally I'd like to encourage the 'box to do something it's reluctant to.
Paddle shift
- StuBeeDoo
Paddle shift
- lezmtaylor
Paddle shift
I would suggest'' Cruise Control '' if you car is fitted with it and it will '' engage '' at such a low speed.!!!!!!!!!!!!!
Paddle shift
BMWs don’t like engaging below 20mph unless you have Traffic Jam Assist which works down to zero.
Pretty soon we’ll only need 3-speed boxes, 1st, 2nd and R.
Never anthropomorphise computers. They hate that.- StuBeeDoo
Paddle shift
lezmtaylor wrote: Wed Sep 20, 2023 12:20 pmI would suggest "Cruise Control" if you car is fitted with it and it will ''engage'' at such a low speed.
Yep! Mine only works above 20.X5Sport wrote: Wed Sep 20, 2023 1:43 pmBMWs don’t like engaging below 20mph unless you have Traffic Jam Assist which works down to zero.
...... If the "I'm right because I can shout louder than you" brigade have their way.
Do not get me started on "activists".
Paddle shift
Go back to the rubber band powered Daf's but doubless even they'd have restrictions dumped on them.X5Sport wrote: Wed Sep 20, 2023 1:43 pm BMWs don’t like engaging below 20mph unless you have Traffic Jam Assist which works down to zero.
Pretty soon we’ll only need 3-speed boxes, 1st, 2nd and R.![]()
I find it ironic that EVs are fast as well as 'clean', though what do they cost in terms of fossil fuel to produce. And generally, speed limits are being steadily reduced. Fast cars that you can't enjoy to its fullest.
Why is there no emphasis on green fuels, proven to work in IC engines with no modifications.
- StuBeeDoo
Paddle shift
That one has been puzzling me, too.sapphireblack wrote: Wed Sep 20, 2023 2:01 pmWhy is there no emphasis on green fuels, proven to work in IC engines with no modifications?
Paddle shift
I think (but might be wrong) that the current challenge with Green Fuels such as synthetic petrol is the cost of actually making them. Large parts of the world run in Ethanol but although that burns clean, its emissions are worse - never mind needing acres of land to grow the ‘producer’ crops. Most European cars can’t run in the stuff without mods either.
If we can solve the hydrogen production and on-board storage challenge then that might be an answer. EVs aren’t either, but are amongst the solution. Mine only has D, N and R. No gears, so no paddles.
Never anthropomorphise computers. They hate that.- lezmtaylor
Paddle shift
No mention of LPG as yet !!
Paddle shift
That’s coz us tractor drivers can’t use it……but it’s a good point. It has been very quiet on that front.
Paddle shift
You'd have thought, or i would, that developing green fuels for millions of existing vehicles would be cheaper than the money poured into EVs and all that goes with them. Just my 2p's worth.X5Sport wrote: Wed Sep 20, 2023 4:23 pm I think (but might be wrong) that the current challenge with Green Fuels such as synthetic petrol is the cost of actually making them. Large parts of the world run in Ethanol but although that burns clean, its emissions are worse - never mind needing acres of land to grow the ‘producer’ crops. Most European cars can’t run in the stuff without mods either.
If we can solve the hydrogen production and on-board storage challenge then that might be an answer. EVs aren’t either, but are amongst the solution. Mine only has D, N and R. No gears, so no paddles.![]()
Lobster Pot
Paddle shift
We are using hvo fuel at min in our trucks it’s bizzare stuff no smell to it and looks like water down side you loose a few horses which is a nightmare on hills and dropped from 52 to 51 mph on flat
Paddle shift
I’m not sure the development is the issue, the fuel itself is significantly more expensive to make and capacity isn’t there. Currently production worldwide is 240k barrels a day but 100M barrels is needed. The cost of scaling up is higher than the shift to EVs, but they are an option. Again, these are probably part of the solution. I think whatever the final answer is (and I’m not sure it will be in my lifetime, will by necessity be a mix of technologies dependant on use case. That answer will need to solve the CO2 and other pollutants issues. Efuels use CO2 capture and green energy, but we don’t (yet) have the green energy surplus to do this.
Paddle shift
As a world issue its not going to trouble me overly much, though i don't say that in a blasé way. Whats left of my lifetime will be deisel powered transportation.
- StuBeeDoo
Paddle shift
That ^^^ is my stance as well. I've always maintained that I will give-up driving at 80 - if I live that long. 2038 isn't that far away, in the grand scheme of things.sapphireblack wrote: Thu Sep 21, 2023 8:54 pmAs a world issue its not going to trouble me overly much, though i don't say that in a blasé way. Whats left of my lifetime will be deisel powered transportation.
Paddle shift
I’m the same (in terms of giving up, and no it’s not that far off for me either!). Having a younger wife means I have a chauffeuse (if that’s a word!), but don’t tell her
