BMW X1: Parking Distance not working
Discuss anything to do with the BMW X1 (F48). Problems, How To Articles & Performance topics can currently be discussed here also.
everson
Post by everson » Tue Feb 01, 2022 11:18 pm
Hey guys
I have a 2015 X1 diesel . Recently I have had a fault with my PDC display (see pictures) and my PDC button has a flashing green light.
I'm trying to figure out where to start. I've read it could be a sensor but would one faulty sensor make all of them not work? If not that what else could it be.
Thanks in advance.
Post by X5Sport » Wed Feb 02, 2022 6:46 am
No pictures? You need to use the ‘Add Files’ button just above the ‘Post Reply’ button (at the bottom of the reply text box) or they don’t upload. You can’t insert them into a post any other way.
One sensor can cause an issue but not normally at both ends. Put your ear to each in turn and you should be able to hear a gentle ‘ticking’ as they pulse. You could have a bad wire or control unit.
Oh, and :hi: :hi: too. :D
Post by Alan Gunn » Wed Feb 02, 2022 7:08 am
I had 1 fail on my e53 and the system stopped front and rear and the button flashed just like yours.
As said above you will hear the good ones clicking.
Turn ignition on but don't start the car and select reverse then put your ear to them.
everson
Post by everson » Wed Feb 02, 2022 10:00 am
X5Sport wrote: Wed Feb 02, 2022 6:46 am No pictures? You need to use the ‘Add Files’ button just above the ‘Post Reply’ button (at the bottom of the reply text box) or they don’t upload. You can’t insert them into a post any other way.
Thanks for the warm welcome lol.
I have attached some pictures. So the one of the dash is just how my sensors are registering, with nothing. Also the green circle is showing my pdc button just flashes green.
everson
Post by everson » Wed Feb 02, 2022 10:01 am
Alan Gunn wrote: Wed Feb 02, 2022 7:08 am I had 1 fail on my e53 and the system stopped front and rear and the button flashed just like yours.
hey pal thanks for this. Will putting it in reverse also trigger the front ones to try turn on or only the rears?
everson
Post by everson » Wed Feb 02, 2022 3:16 pm
Hey guys does anyone know of any good write ups / videos on the front and rear bumper removal for the X1 F48? Looking to do some prep reading as it mostly likely maybe required. thanks
everson
Post by Alan Gunn » Thu Feb 03, 2022 6:18 am
Selecting reverse activates the front ones as well on my e53.
Can't help with bumper removal but have you googled it.
Post by X5Sport » Thu Feb 03, 2022 6:52 am
You may be able to get to the sensors at the front via the wheel arch (remove the trims) and the removable trim panels below the centre ones? Not sure about the rear though.
everson
Post by everson » Sat Feb 12, 2022 11:37 pm
X5Sport wrote: Thu Feb 03, 2022 6:52 am You may be able to get to the sensors at the front via the wheel arch (remove the trims) and the removable trim panels below the centre ones? Not sure about the rear though.
So finally got round to Testing out the sensors and my issue seems to be the front right if in the car or front left if standing outside the car (see pic). I know with electrical components on vehicles some things prefer to be OEM and others are fine aftermarket, so my questions are:
1) Can I go aftermarket with these sensors, looking over eBay and motor factors. Or is OEM best for this part
2) Are these sensors all the same size, there isn't a different size for middle ones to the far end ones?
Thanks in advance.
Post by Alan Gunn » Sun Feb 13, 2022 6:45 am
Not sure on your car but on my 2002 e53 x5 there are outside and inside ones listed.
But i think any fit it is the holder part that makes the difference.
Did you look on realoem for the part number then search for it.
https://www.realoem.com/
everson
Post by everson » Mon Feb 14, 2022 12:59 pm
Alan Gunn wrote: Sun Feb 13, 2022 6:45 am Not sure on your car but on my 2002 e53 x5 there are outside and inside ones listed.
Thanks for this, this site is a gamer changer to be able to find part numbers and compare, as there are about 40 sensors that look the same but will not work. thanks again.
Post by marti » Mon Feb 14, 2022 1:31 pm
Go genuine if you can, as a guide when looking for car parts left/right always look at it from the rear, so for a UK vehicle, driver side would be Righthand side and passenger Lefthand side :thumbsup:
everson
Post by everson » Sun Mar 06, 2022 11:31 pm
Hey guys,
Just wanted to give an update on how things went, so finally go round to changing the sensor on my car, I actually replaced two sensors as one was gone al together and another I had a knock that side and it had recessed it in some. Whilst I did the whole job of taking bumper off and wheels to get to rivets, o actually did more work than I needed to. With the X1 e84, it seems you only have to remove , under tray , wheels to get out rivets, a PART of the wheel arch liner (see pic) and then you can simply reach in behind the bump and swap them out. On the side where I took a knock it appears the holder for the sensor has cracked so it does not sit well no matter how much I pus it from behind. Bit either way it wasn't the worse job, I really appreciatenall who offered help, I always like to research before I attempt any job and it's great when others help to aid this.
Thanks again
Post by Alan Gunn » Mon Mar 07, 2022 6:52 am
Glad you got it sorted out.
