Jack Lift points
JONM50D
Jack Lift points
Post by JONM50D » Mon Feb 25, 2019 3:19 pm
Hello can someone confirm the front jack lifting point on my M50D, is it the circle in-between the 2 x holes as in image?
Many Thanks,
Front Jacking Point F15 M50D.jpg (37.07 KiB) Viewed 20486 times
gmc15
Re: Jack Lift points
Post by gmc15 » Mon Feb 25, 2019 3:57 pm
The jacking point for each side is just behind each front wheel and looks like this
https://xdrivers.co.uk/forum/download/f ... iew&id=553
Jacking point.jpg (118.2 KiB) Viewed 20482 times
JONM50D
Post by JONM50D » Mon Feb 25, 2019 6:58 pm
Thanks, I am aware if these, but wish to jack the whole front end up in one go. I beleive there is a front end single jacking point.
Post by X5Sport » Mon Feb 25, 2019 9:26 pm
From what HenryM3 found (on your other thread about same) it is in the middle of the rectangular area just beyond the circular depression in your image. If you have a circular hard rubber (or similar) pad you can put between the car and jack (safely) that should help.
JONM50D
Post by JONM50D » Wed Feb 27, 2019 9:58 am
Many thanks found it, and jacked up car with no problems.
