Transfer case fluid change
Bradders
Post by Bradders » Fri Mar 30, 2018 9:49 pm
If you haven't changed the transfer case fluid, I have to say, it is 20 minutes well spent. My X3 has just tipped over the 100K miles, I could feel what I can only describe as a mild stutter through the auto in first and second and changing the oil has eliminated it. What a massive difference! The old fluid was a dark brown colour, the new Ravenoil, light in colour and less than £20 from John Craddocks Land Rover specialists. Easy DIY job, all you need is a 16mm spanner and a container to catch the oil (700 ml).
derin100
Contact:
Re: Transfer case fluid change
Post by derin100 » Tue Apr 10, 2018 11:55 am
I'm considering doing this myself on my newly acquired X3 but when I watch a YouTube video on how to do this they then talk about resetting the transfer box adaptations using a scan tool...which I don't have. Is this essential?
Thanks.
Bradders
Post by Bradders » Tue Apr 10, 2018 7:22 pm
I stand to be corrected but I don't think this is necessary, I certainly didn't and the difference is as I say, chalk and cheese. The box seems so much smoother, with none of the juddering that I previously had under acceleration.
Regards,
Matt.
XK8
Post by XK8 » Tue Aug 07, 2018 5:17 pm
Hi, im all set to do this, one Q if i may:-what wizardry device did you use to pump the oil in. I have the ravenoil fluid, but noticed the filler hole is up higher than pouring angle when looked st the transfer box.
Cheers,
Tony
Current Garage
2007 BMW X3 3.0sd M-Sport
2004 Jaguar XK8
2010 BMW 330i coupe
1978 Yamaha XT500
Bradders
Post by Bradders » Thu Aug 09, 2018 8:51 pm
Tony,
If I remember rightly, I put a long piece of tube over the end of the smaller filler tube and simply squeezed the bottle forcing it along the tube and into the casing. I was lucky as I had a piece of clear tubing of the right bore to make a snug fit over the filler end of the bottle.
Good luck with it.
Matt.
XK8
Post by XK8 » Sun Sep 30, 2018 8:28 pm
Cheers Matt, I squeezed the be-jesus our of the bottle until the fluid came out of the fill hole. Now to tell the car I’ve changed the oil, via the ista software.
BTW folks, the old oil was nasty, I strongly suggest y’all change the transfer box oil.
Diffs and gearbox will be the next oil changes.
Current Garage
2004 Jaguar XK8
2010 BMW 330i coupe
1978 Yamaha XT500
lezmtaylor
Post by lezmtaylor » Tue Oct 02, 2018 9:45 am
Slight hijack,but, I have a 2002 4.4 E53 and am about to change the transfer box oil : does the box need to be reprogrammed.
Regards,
Post by Alan Gunn » Tue Oct 02, 2018 10:53 am
When i asked about getting this done at my local indi he said it had to be reset.
Something about wear indicator i think he said.
The Foxwell nt510 scanner does a reset but not very clued up on it myself.
Bradders
Post by Bradders » Tue Oct 02, 2018 9:39 pm
I have to admit that when I changed mine, I did not plug it in to any electronic wizardry, I simply changed the fluid. I would be interested to know if it makes any difference beyond changing the fluid.
Matt.
XK8
Post by XK8 » Wed Oct 03, 2018 3:33 am
Hi, I read a few posts on t’web that recommend a transfer box reset (oil change) on ista. Not too sure why, but I guess it’s the difference in wear/slip measurement with old oil and new oil. I will let you know if it has made any difference once it hits the road. Just getting all the jobs done that I’ve put off over the fabulous summer, front discs, pads, trans box and EGR removal/mod. The X3 is my winter warrior, my XK8 garage queen does not like the taste of salt :)) .
Tony.
Current Garage
2004 Jaguar XK8
2010 BMW 330i coupe
1978 Yamaha XT500
