Evening,
After reading a multitude of poss about people coding their cars using wifi adaptors and the Carly app it all sounds very simple and good value at around £35-£40, could someone confirm the below item is what I require to pair up with the Carly app?
http://www.ebay.co.uk/itm/WiFi-ELM327-C ... SwHnFVpA5d
Si
Carly Coding - Wifi Adaptor
Sit
2010 X5 30d M Sport Carbon Black | Camel Leather, 20's | HUD | Shadowline | Privacy | CIC iDrive | Adaptive Drive | Pro Nav | Loudspeaker Audio | High Beam Assist | Enhanced Bluetooth | Media Pack | Bum Warmers!
Glen
Re: Carly Coding - Wifi Adaptor
Hi Si I'm no expert in tech but I think this is the one you need
http://www.ebay.co.uk/itm/Original-Carl ... Sw-89ZTTjJ
2012 X5 40d msport Mine now gone
2010 320d convertible WIFE'S
2006 Mini cooper convertible WIFE'S gone
2017 X5 m50d m performance pack
Sit
Thanks Glen, I saw that one but then read a thread where people were linking to the other one, however it has to be said I want to make things as easy as possible and eliminate potential for errors so I am guessing the Carly adaptor with the Carly app would make more sense??
Si
Si
- snrbrtsn
The first unit is a generic obd Adaptor and is known to be troublesome
The second link is the genuine adaptor, I believe their slightly cheaper on Amazon,
The adaptor itself allows the basic (Lite) package from Carly
Though pretty useless, allbeit I think it does allow fault code reading.
The Pro app (downloadable)is required for coding & parameter monitoring, there is in app purchases for battery coding & forced dpf regens
The adaptor is circa £50, the app is A N other £40 from App Store, useable on iPad and iPhone
The Carly adaptor is not tied to a specific car / chassis and can be used on multiple cars..
However, there is restrictions to coding as per your cars specifications, if the modules not there, there’s nothing that can be coded...
One of the main benefits is that all wrong doings can be reversed, prior to a coding session an image is made and stored on device (phone) , this allows easy reversal as the image is created per date stamp!
Sit
Very informative and just what I needed to know! Thank you for that, I think I will definitely go with the gen Carly adaptor in that case.
Will have a search on Amazon to see what price it is available.
Si
Si
sam82
[quote="Sit"]
Evening,
Si
I will buy directly from Cary website ( I got mine directly from Carly)
http://www.mycarly.com/product/bmw-app/
Evening,
Si
sam82
Sit
Thank you for the offer and PM, I think I am going to go ahead and buy adaptor and app, I read the coding list and was AMAZED at the options!!!!
Si
Si
sam82
Good luck
, keep us posted on the progress
