So this is 2 of 2.
Bonnet cable snapped at the lever in the drivers footwell. Managed to get the bonnet open, and replacing the first cable in the system is actually pretty simple.
but
Once it was all reconnected, it still wouldn't open. When I pulled the lever, I could see the 2nd cable (bowden cable??) would move. I think it usually runs around the side of the wing, over the headlight to the driver side latch. But I when pulling the lever I can see it moving away from the wing. In other words instead of the cable inside the sheath moving, the whole sheath was being pulled.
It seems to me, that the cable is supposed to be clipped into something, but I cant see what. For the time being I've wrapped the cable under one of the headlight adjuster screws, which takes up some of the slack and stops the sheath moving.
Anyway... short version... is there some kind of clip that the cable is supposed to clip into.. probably near the headlight? If not, why is my whole cable moving?
Appreciate this is difficult to picture on a forum, but any suggestions welcome.
Bowden Cable Routing?
Re: Bowden Cable Routing?
Any clues here in this slide from the parts database?
themoog
Mine has a sort of plastic bracket that the cable goes through that clips to the inner wing just by the air filter. Is that what you mean? I would think there is something above / in front of the radiator as well.
Nick73
Thanks guys.
X5sport - I looked at the parts map before, but there is no sign of a clip
Themoog - I think the clip you talking about is the one where the cable from the inside the car connects with the bowden cable.
In my case, thats fine, but I still need something to hold the cable as it goes round the bend behind the headlights.
Although Im starting to suspect that the second cable that goes to the first latch is actually also broken. Which is a PITA as so far as i can tell that cable comes with the latch and changing the latch involves removing the front bumper...
Nick73
On a separate note, while Im working out how to fix this..... does anyone know if an MOT tester has to pop the bonnet for any reason?
They have to check brake pipes, joints on the steering g column, etc etc
Nick73
I figured out the problem, the plastic connector that clips to the bonnet kept popping out of its clips. Several cable ties later and the MOT is all done!
Cheers chaps
Cheers chaps
Nick73
Thanks X5, quite a result, as I was hoping for the best... but fearing the worst! Although she has been sat up for a while because of the problems, so I will be posting a few more Q's now she all legal again (ooer!) :-[
