Newbe
Joyner
Newbe
Post by Joyner » Mon Apr 11, 2016 9:55 pm
Hi all just got my first bmw and as you can guess it's e53 x5 d sport  facelift and love it
Wot I need now is some info Wots the best software to get for code scanner.
Pdc has started to play up after a week and can't connect my phone with Bluetooth at all seems like it broke
Any help would be great thanks
toonarmy
Re: Newbe
Post by toonarmy » Mon Apr 11, 2016 10:02 pm
Where u based
X5 e53 3.0d 53 plate and Honda vtr1000 fun time
Joyner
Re: Newbe
Post by Joyner » Mon Apr 11, 2016 10:07 pm
Bridgend south wales
SLX530
Re: Newbe
Post by SLX530 » Mon Apr 11, 2016 10:17 pm
Your brief list of issues can only be answered briefly but if you can offer more of a description of the problems then answers can be more complete.
Code reader is bmw scanner 1.4
Pdc Is normally the sensors... Put your ear to them and listen for a ticking whilst the ignition is.on, engine off and shifted into reverse gear.
Bluetooth ulf is often difficult to pair, do a search here, but ignition position 1, press pairing button for 1 second and turn key to ignition position 2 whilst depressing the button for another couple of seconds and the Bluetooth pairing should begin. Also ulf modules are fussy, so where a generation 1 may pair with Nokia windows phone and iPhone,  it may take a later generation for other mobiles. There are 13 generations.
And welcome!  :)
Joyner
Re: Newbe
Post by Joyner » Tue Apr 12, 2016 7:21 am
Pdc was working fine but now when I select reverse it beeps for a second and then just flashes
With the Bluetooth I have done the set up steps but nothing happening.no msg on the clocks or radio
Car is 05 with sat nav and Dsp if that makes any difference
Are the scanning software with obd lead on eBay any good just they seem very cheap
grumpywurzel
Re: Newbe
Post by grumpywurzel » Tue Apr 12, 2016 7:41 am
One or more of your sensors may be broken for the PDC, I bought BMW Scanner from ebay and although it can be a bit of a nightmare to connect and get working (I have a fairly old Win 7 laptop that runs it ok, not sure if newer machines are ok or not) it is fairly cheap. If yours is like mine and one of the front sensors has gone belly up you can disable the front sensors.
Bluetooth, ok again not always easy and depends on what mood your car is in. Have you got the static bluetooth code that comes with your car? Its on a module in the boot floor if u haven't. Do you get the 3 flashing lights on the top right hand corner of the radio when u start the pairing process?
2005 X5 3.0d Sport
toonarmy
Re: Newbe
Post by toonarmy » Tue Apr 12, 2016 8:29 am
Check you have a Bluetooth module first if so then check wiring in centre console where Bluetooth switch is for some reason the plug on mine was off refitted all ok but best get software so you can clear other phones etc much easier I've just been working down your area for 8 weeks but across size well now always have scanner with me
X5-D-Sport
Re: Newbe
Post by X5-D-Sport » Tue Apr 12, 2016 7:03 pm
Welcome NEWBIE,
if it's of any help, I'm very close to you in Caerleon nr Cwmbran...
You're welcome over to see what we can fix & track down..
Private mail me & swap numbers.
Regards
Grant B
