stupid question go easy on me!!
petershamu
Post by petershamu » Tue Oct 27, 2015 6:53 pm
ok here go's !!
i am driving along in D  can i when moving shift into tiptronic and change gears or do i have to start of in manual.
im 45 and havent a clue!!
buzz
Re: stupid question go easy on me!!
Post by buzz » Tue Oct 27, 2015 7:29 pm
when you push it across it goes into 'sport mode' auto.....push forward or back and you are in manual tiptronic.....
petershamu
Post by petershamu » Tue Oct 27, 2015 7:31 pm
but can i push it across when travelling??
AW8
Post by AW8 » Tue Oct 27, 2015 7:45 pm
Yes.
petershamu
Post by petershamu » Tue Oct 27, 2015 8:46 pm
thanks guys,  not a clue!!
graemeX5
Post by graemeX5 » Tue Oct 27, 2015 9:08 pm
And also back into D after  :)
Post by X5Sport » Tue Oct 27, 2015 9:54 pm
All that will happen is the box shifts into the Sport/Steptronic mode and it usually changes down one gear (as long as you are below 100mph in 6th......)
The gears will then each be held until higher rpm...even to the red line....before shifting.
Moving the shifter in and out of Sport/Steptronic in motion is normal.  :)
petershamu
Post by petershamu » Tue Oct 27, 2015 10:19 pm
cheers guys expect a few dumb questions from me!!
great forum, no one takes the mick if you dont know.
im an "expert" on some other forums and they are hell with newbies!
Steamyrotter
Post by Steamyrotter » Tue Oct 27, 2015 11:54 pm
The only dumb question is the one that is never asked...
Also..
Dont try putting it in reverse or park when driving...
Please note...
pvr
Post by pvr » Wed Oct 28, 2015 9:09 am
... or rolling.
We had a discussion some time back about the overheating of the gearbox if you left it in neutral when going down a hill or so.
911 50th anniversary -
Post by X5Sport » Wed Oct 28, 2015 6:23 pm
That's a definite do not, unless the box has a 'coast' function, and I don't think that ever existed on any version before the F15.  Coasting is a waste of time anyway as you use more fuel keeping then engine idling!
AW8
Post by AW8 » Wed Oct 28, 2015 7:19 pm
One minor bit clarification.....When driving long moving selector to left causes boxto enter sport mode whereby revs are higher before gear change. Moving back andforth then causes manual mode to engage with redlining unless changed  up earlier. The box downshifts for you. If yiu go from sport to D it reverts to normal auto  mode.
