wiring for lighting board
strummer
Post by strummer » Wed Sep 09, 2015 2:12 pm
hi
I have now bought a 4 bike carrier but my lights are obscured whats the best option for a light board,are there any plug and play if not what else is available?
strummer
Re: wiring for lighting board
Post by strummer » Wed Sep 09, 2015 7:17 pm
it looks like there is a socket in the boot to plug into,where do I get a cable to suit?
Steamyrotter
Post by Steamyrotter » Wed Sep 09, 2015 8:20 pm
You will need the towbar wiring kit to do that.
Would be best to go for the proper module installation kit as will help in resell and will take care of the interfacing to the dashboard and the bulb failure stuff....
Also wil turn off the reversing sensors when plugged in to stop teh continual tone of spotting the bikes!!!
Please note...
TimX5
Post by TimX5 » Wed Sep 09, 2015 10:16 pm
Give pfjones a call they'll sort you out a kit with relay ect.
strummer
Post by strummer » Thu Sep 10, 2015 7:40 pm
local trailer company going to sort it,thanks for the replies
Steamyrotter
Post by Steamyrotter » Thu Sep 10, 2015 8:32 pm
just make sure they dont just splice to the rear lights...
best way to blow the LCM module...unless you use an appropriate bypass relay kit...
In which case the proper module would still be your best bet....
Please note...
Post by X5Sport » Thu Sep 10, 2015 9:27 pm
Use the proper kit - PF Jones provide.  As above, you'll blow the LCM (Lighting Control Module) and they are VERY expensive to replace as it controls all of the vehicle lighting.
If they're using the right kit then fine, but unless they understand BMW wiring, don't let them Scotchlock the wires!
strummer
Post by strummer » Fri Sep 11, 2015 5:17 pm
Ok cheers will give them a ring
strummer
Post by strummer » Sun Sep 13, 2015 2:57 pm
Local company were going to use a generic kit so I have ordered a specific kit from pfjones and am going to have a go at fitting it myself
TimX5
Post by TimX5 » Sun Sep 13, 2015 7:25 pm
[quote="strummer"]
It's a doddle to fit yourself
Steamyrotter
Post by Steamyrotter » Mon Sep 14, 2015 1:07 pm
[quote="strummer"]
Best thing to do mate..
Peace of mind etc
Even for resale value....
Please note...
strummer
Post by strummer » Mon Sep 14, 2015 2:46 pm
do I have to disconnect the battery to plug the lighting connector in,dont want to have to remove the spare wheel if I can help it,can do without pulling my back out  :)
Post by X5Sport » Mon Sep 14, 2015 3:11 pm
Ideally yes.
There is a strap that will help 'lift' the wheel.  It hooks over the lower tailgate (into two slots in the top edge) and when you open the tailgate it lifts the spare.... :)
strummer
Post by strummer » Mon Sep 14, 2015 3:37 pm
Ideally yes.
ok mate cheers
briankerrys47
Post by briankerrys47 » Mon Sep 14, 2015 8:04 pm
Ideally yes.
[/quote]Well you live and learn  :o :o :o
