REAR BRAKES ALWAYS STICKING
nickid
Post by nickid » Tue Aug 11, 2015 9:58 pm
I am having a hard time with my rear brakes.
I have replaced the calipers, bled them and the system twice.I have new pads and disks, and made sure pads can move.
What am I missing?
Re: REAR BRAKES ALWAYS STICKING
Post by X5Sport » Tue Aug 11, 2015 10:20 pm
Have you bled the ABS system properly?  If at any time air got into the system, or an incorrect procedure was followed by a garage then you need to have a computer connected to the car to run the correct software controlled 'bleed cycle' which runs the entire system valve train through the correct sequence.  You usually need the bleed nipples under a light vacuum to do this properly.
BMW Dealers have the correct kit, as will Bosch Autocentres.
nickid
Post by nickid » Tue Aug 11, 2015 11:27 pm
Can I bleed the abs myself?
Post by X5Sport » Wed Aug 12, 2015 6:30 pm
If you have a copy of the BMW GT1 software set, yes.  Otherwise no.  The software runs a special calve open/close sequence.
Some who have tried to sort it without have bricked the ABS modulator so be careful..  :(
nickid
Post by nickid » Wed Aug 12, 2015 11:13 pm
Looks like a trip to bmw  :'(
Post by X5Sport » Thu Aug 13, 2015 4:56 pm
Or a Bosch Autocentre.  They should have the right kit too.
