Cabin temperature out of control..
X5-D-Sport
Post by X5-D-Sport » Sat Feb 21, 2015 8:33 pm
New problem...
The internal cabin temp is either sweltering or... sweltering.... or tepid...
Just fitted a new engine thermostat & have a decent water temp now at half way across the dial instead of 20%...
Is there an internal temp sensor that the electronic settings measure against ?
At the moment, even with sub zero temps / 1 or 2 degrees externally, the interior is toasting if dash setting controls are 17' or above.
Previously, setting to 20' with air con "on" to de-humidify was good and stable cabin temperature, but now the air con does not chill, but does remove humidity...
Any thoughts ??
Re: Cabin temperature out of control..
Post by X5Sport » Sat Feb 21, 2015 9:35 pm
Check the position of the roller in the centre upper dash.  If it's not in the neutral, centre'white' bar position (no red or blue dots) then it will override the a/c settings.
Is your a/c running properly, ie you can cycle it right down to 16C and the car gets cold, or up to 32C and it gets hot again?  Is your a/c gas level OK?  That might also affect the temp if there is no cooling function to mix with the warm air.
X5-D-Sport
Post by X5-D-Sport » Sun Feb 22, 2015 12:26 am
Ahh... the roller in the centre.... didn't know about that one, will go check.
Thanks again.
Grant  ::)
X5-D-Sport
Post by X5-D-Sport » Sun Feb 22, 2015 12:44 am
Hi Richard... re the roller position at Centre dash...
12.30  night time... damned freezing outside,  but had to have a peek...and sew where this roller knob was set.
It does not have a white centre position bar marking.... but when centralised.. both Red & Blue dots are visible at each side of the roller knob thingy...
So, set it at the MID position...  will see what happens when I zip out for a drive in the morning some time..
Post by X5Sport » Sun Feb 22, 2015 9:01 am
briankerrys47
Post by briankerrys47 » Sun Feb 22, 2015 10:40 am
[/quote]IS he back yet Richard  O:-) O:-) O:-)
X5-D-Sport
Post by X5-D-Sport » Sun Feb 22, 2015 10:54 am
Almost... will let you know shortly.
Richard, can you PM me with a fone number... couple of technical qns I would like to ask plz.
Grant
X5-D-Sport
Post by X5-D-Sport » Sun Feb 22, 2015 8:26 pm
Well Richard... an update.
The thermostat changed gives a little more power and a marginally sharper response with the engine at proper temp & needle in the middle of the gauge, as opposed to near cold !
The much higher air/heater as a result too...
Set the dash roller knob centrally...
Just driven Salisbury to Luton (for my sins) and the temp stabilised where by i set it at 18' and comfortable temp achieved.
I think the Air-Con needs re-gassing as it makes no temp difference what so ever if on or off !
Will get this looked at next week.
Meanwhile, enjoying the summery T shirt weather & having a nice BBQ later..... NOT... lol
Grant B
