Water Pump Bolts Removal ???
X5-D-Sport
E53 2004 Facelift diesel 218..
Went to replace the thermostat today....
to discover the most ridiculous bolts ever put on a vehicle... possibly to prevent over tightening I guess...
Like tapered Torx heads... sockets wont remove them...
Any one know what they are called, so I can get some special sockets to remove them ??
- Greydog
Re: Water Pump Bolts Removal ???
Real OEM says M7 x 38 torx screw. Maybe someone has been there before and damaged them?
X5-D-Sport
Nope,
These are the original fitment...
They are best described as a tapered torx bolt... with external points... but the external splines are not parrallel... the taper off...
Ebay has lots for sale as a pump set of bolts....
But these things truly are a ridiculous concept...
X5-D-Sport
What are these bolts called ? and what will undo them...
they are approx. 6mm thread, & made of Aluminium..
eBay item number: 350613360840
They are 8mm x 32mm Aluminium 'ASA' type E-Torx bolts. Single use only.
The ones you have listed are not recorded against the E53! As above the OEM ones are 7x38 Torx
Usually either a Torx spline key, or E-Torx socket/spanner should do the job. The 'E' stands for 'External'. It could also be a Torx-Plus but they do use the same tools.
Assuming it's an M8 thread then you need an E10 socket. M6/M7 is an E8 socket. For some reason the E tool numbers are not the same as the T tool number! T tools match the thread size. T tool is the 'normal' Torx bolt where you put a key in.
They came into being to allow faster assembly times as the tool can be slightly offset to tighten them.
X5-D-Sport
Excellent Richard... Thankyou...
A trip to Halfords it is later.... Wonder what the chances are of the Halfords Monkeys having these sockets ?
Regards
GB
Regards
GB
Should do. My Halfords pro socket set has them.
X5-D-Sport
So Richard,
What size do you think these Thermostat bolts actually are ?
According to Realoem they should be Torx 7x38mm. Should therefore be a T40 or T50 key/spline bit. What have you found them to be? The OEM part number is: 11517789351.
Those look like the proper 'recessed' type Torx bolts, but your picture shows external Torx which makes me wonder if your pump has been changed and a different type used? The ones you describe should take an E8 socket.
Can you take a piccie of what is on the car?
Richard.
Richard.
X5-D-Sport
Hi Richard,
These water pump bolts, are M7 x 28mm... They were a factory fitted E-Torx M7 bolt...
The E-Torx Sockets wizzed them off easily, and for the 1st time in months my Beastie has a proper temp reading now.... Hurrah...
Thanks for the help & suggestions.
At least you solved it. Just HTH
