Lighting Issues
7builder
Lighting Issues
Post by 7builder » Wed Dec 31, 2014 9:47 am
The dashboard display on my 2003 3.0D is constantly telling me to check tail lights and check brake lights and the passenger side indicators occasionally flash really fast. I have checked all of my lights and they are all working fine. I have done a search on this forum and I have removed the rear light units and cleaned the contacts and tracks for all of the bulbs but all to no avail.
I would appreciate it if someone could shed some light (sorry) on what the problem could be as it has got me stumped.
Happy new year everyone.
X5-D-Sport
Re: Lighting Issues
Post by X5-D-Sport » Thu Jan 01, 2015 2:34 am
Im getting spurious warning in the last 2 weeks also...
Incl suspension levelling warnings...
And the latest gem is my from fogs bailing out whwn main beam is illuminated...
I checked the battery voltages after a cold night... down to 11.2 volts... and im pretty sure that a dying battery will be giving me these issues....
Maybe check your pre start voltages in the morning...
As a member here suggested...
A good battery will hold just over 13 volts, charge at approx 14.2
And should deliver 12.5-13.5 volts after the lights have been on for 30 minutes without having starting the engine before or after this voltage test.
If you have a low voltage, it seems that the consensus of opinion & experience ... is weird warnings on things that are actually ok...
Check your battery voltages before you spend money on diagnostics & stuff..
TimX5
Re: Lighting Issues
Post by TimX5 » Thu Jan 01, 2015 9:41 am
[quote="7builder"]
I had a similar problem on my last car Peugeot 407 X's sport 2.2hdi the dash was saying there was a brake light fault and indicator fault but they worked fine , I went ahead and fitted new bulbs anyway and the fault was cleared , abit weird really but it worked , worth a try.
Tim
X5-D-Sport
Re: Lighting Issues
Post by X5-D-Sport » Thu Jan 01, 2015 11:57 am
Hi Tim, good point...
There is a possibility that the bulb connector has a little corrosion on it, or the bulb is on it's last legs causing the resistance metering to increase, hence giving the error report...
This is why a big resistor is often used with LED lights to increase the current flow and negate a failure reading at the dash computer...
7builder
Re: Lighting Issues
Post by 7builder » Thu Jan 01, 2015 5:45 pm
Thanks guys I will check the battery voltages first thing in the morning and failing that take a trip to Halfwits for a bucket load of bulbs and swap out the lot. I've recently managed to get hold of a Dimwhits trade card so will be interested to see what sort of discount I will get (if any).
gmc15
Re: Lighting Issues
Post by gmc15 » Thu Jan 01, 2015 7:00 pm
[quote="7builder"]
BMW's are prone to showing light failure problems if poor quality bulbs are fitted. I had this problem with a 5 series showing bulb failure for the rear light when there was no obvious problem. I fitted decent bulbs (Lucas I think) and the problem went away.
Might be worth while changing the bulbs for quality ones.
HTH
x6 M50d
7builder
Re: Lighting Issues
Post by 7builder » Thu Jan 01, 2015 8:45 pm
Halfords do their their own brand, GE(Original Spec) whatever that is and Bosch so I guess Bosch it is then.
7builder
Re: Lighting Issues
Post by 7builder » Fri Jan 02, 2015 6:09 pm
I went to Halfords today and decide to swap out all of the bulbs for Bosch. Headlights (H7 main beam not high beam), side lights, tail lights and brake lights. I used my trade card for the first time and was pleasantly surprised at the discount. The receipt showed £19.99, £3.99, £3.99, £2.99 for all the bulbs and £2.99 for screen wash. Total after discount was £18.99 - happy days.
So I swapped out all of the bulbs at the front and the rear offside without a hitch but have found a problem with the rear nearside cluster. I had to remove the multi plug connector so I could get my pork sausages any where near the stop/tail light bulb and when I reconnected it the entire light cluster was dead. I removed the multi plug and reconnected it and had 1 tail light and no brake light. If I wiggle the harness at the back of the plug the lights will come on and illuminate at different brightness depending on the position. So it looks like I have found the source of the warning messages  but as it was getting dark and there is not a lot of slack on the cable I was not able to examine the plug and cables in any great detail. That will have to wait until another day.
X5-D-Sport
Re: Lighting Issues
Post by X5-D-Sport » Sun Jan 04, 2015 2:51 pm
7Builder...
Connector plug issues.... SNAP... had the same....
I cured that with a fine needle file pushed gently in the socket to get the corrosion off, and a very gentle tweak to the connection pins on the cluster, then a spray of contact cleaner - from Maplin for £2:99 a can...
That solved my problem there, so I sprayed some of this on the other side's connector for good measure..
I wasn't getting warnings, but was aware that one light cluster had dimmer illumination than the other. !
7builder
Re: Lighting Issues
Post by 7builder » Sun Jan 04, 2015 3:18 pm
I'll give that a try but my problem seems to be more like a lose connector or wire as my tail lights will go off completely or illuminate very dimly when I move the wires going into the connector. I had a quick look yesterday and it also looks like someone has been at the wires with those evil scotch-locks at some point as 2 of them have cuts in the insulation. I might have to cut and re-join some of the wires but there isn't a lot of room to work or much slack in the harness to get good access.
X5-D-Sport
Re: Lighting Issues
Post by X5-D-Sport » Sun Jan 04, 2015 10:40 pm
Exactly my point..
Any interference with the connector, ie twiddling the wires, will change the connectivity...
You have answered the problem describing it... back to the needle files  switch cleaner !
chrisn7
Re: Lighting Issues
Post by chrisn7 » Mon Jan 05, 2015 12:46 am
[quote="7builder"]
Its a pity you didn't go for a premium lamp such as Phillips or Osram. The light output from these is vastly superior to OEM. I did this recently as the headlights seemed so dim and the improvement is massive.
