I get this error sporadically. Basically when accelerating hard I get a strange whine from the gear box then get thrown into Transmission Failsafe Program. I think the car sticks the gearbox into failsafe mode to protect the gearbox.
Here is my dilemma - we have a warranty on the car. I have it booked in with Bavarian next week for diagnosis.
If the diagnosis shows the fault is with the gearbox and it needs repaired I can claim back diagnosis and cost of repair.
If diagnosis shows it is something else causing the issue I have to fork out Bavarians £100 / hour fees with no claim back.
Can anyone give me advice on this error? Have the full error codes from bmw scanner 1.4.0 but can't attach?
mattyc
BMX X5 2005 3.0D
Re: Transmission Failsafe Program
You need to upload the images to a photo share site and cross link to them. I use Photobucket, and there are plenty of others. Codes need to be from the gearbox itself.
You need to get it looked at ASAP. It could be the gearbox or transfer box, or a diff.
mattyc
Thanks Richard. Error codes pasted out below. I think I will maybe try and get a local specialist to diagnose first. If he points in the direction of gearbox failure I can take the warranty route.
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
EWS -> 13/01 - Toleration of changing code increased, key 1
0F/3F - Power on reset
23/FF - Toleration of changing code increased, key 2
20/01 - Wrong identification, key 2
0E/01 - DME changing code XOR-error
10/01 - Wrong identification, key 1
A/C -> 21/01 - Park heating Locking valve, Latent heat storage system Cut off valve
SRS -> Shadow-memory:
51/08 - Fault lamp, short circuit to negative or open circuit
50/20 - Power supply, undervoltage
IKE -> BD/90 - Electronic braking-force distribution
8D/90 - EGS signal line disturbed
LCM -> Shadow-memory:
57/01 - Level control system
59/06 - Transmission failsafe program
62/03 - MRS seat occupancy recognition fault
93/06 - Right brake light
ZKE -> A7/04 - Mirror, potentiometer horizontal or cable, passenger's door
95/06 - Interior security: fuse or cable
A5/06 - Mirror, potentiometer horizontal or cable, driver's door
6B/01 - Relay sticking to ground, power window motor, rear, driver's side, closing
Shadow-memory:
83/03 - DWA-Alarm: door contact, driver's door
80/01 - DWA-Alarm: Terminal R
8B/21 - DWA-Alarm: rear window or interior security
PDC -> 11/C6 - Converter, rear right
15/86 - Converter, front right
16/C8 - Converter, front centre left
MID -> 03/0A - No valid status response of TELEPHONE
VTG* -> 54C6/31 - Oil abrasion
SHD -> A092/21 - SHD normalization error
A0A2/21 - SoS normalization error
A088/03 - Switch error
Shadow-memory:
9541/5F - SHD SKB activation
9440/1F - Panic mode activation
9540/42 - SHD Manual roof movement
9441/01 - Manual initializing
9509/41 - SHD Sliding curve
950A/61 - SHD Lifting curve
9609/A1 - SoS Sliding curve
9443/21 - Cancelled initializing
9607/A2 - SoS Position lost, power failure
9608/A2 - SoS Position lost
Shadow-memory:
Shadow-memory:
BMX X5 2005 3.0D
The VTG one is relevant. That's the transfer case. It needs an oil change as a minimum. It isn't a lifetime oil so has exceeded its useful life.
See this thread.
R
See this thread.
R
mattyc
Thanks Richard. Do you think the gearbox would go into "Transmission Failsafe Program" if an oil change is required?
Will chat to the local guy tomorrow.
BMX X5 2005 3.0D
mattyc
Chatted to a guy at Autotechnic in Belfast on Friday past. Extremely helpful and has advise that getting an oil change is definitely the first thing to do (Bavarian would advise the same thing apparently). He also mentioned that if you hear a yelp from the gear box (which I do) then oil change is vital.
Booked in for 1st December will let you know how I go.
BMX X5 2005 3.0D
centurion
I looked at the following the other day and I'm tempted to do the same on my car... any advise re whether listed parts are sufficient or if anything else needs to be added?
http://www.ebay.co.uk/itm/221522006173? ... EBIDX%3AIT
for my info... how long does it take to complete the job / avg. cost of doing so? Thx
